Can't export to feature class called "Drop"
1358
05-03-2023 03:37 PM
Scoth
Pretty self explanatory really. Just can't do it. Got an error saying "Invalid Characters". Is this some database issue behind the scenes?
JoshuaSharp-Heward
Couldn't find any documentation on it but drop is basically "delete" in sql (https://www.w3schools.com/sql/sql_drop_table.asp) so I suspect that's why it's considered invalid. I can confirm I can't export a 'drop' feature class either, it'll work if you add a suffix though.
BarryNorthey
Robert_LeClair
Esri Esteemed Contributor
And if you try to create a fGDB Feature Class called Drop, it says "name cannot be a keyword" for the error - so it's a reserved word as well in a fGDB too.
ChrisUnderwood
And this Esri blog article details the different Reserved Words that apply in different circumstances.
https://community.esri.com/t5/esri-technical-support-blog/words-by-reservation-only/ba-p/898664
