Can't edit an attribute table?!
26772
13
09-30-2022 10:14 AM
DanielPhillipsTTU
Hello All, I'm running the most current version of ARC Pro Desktop and am having an issue when I try to add data to newly created fields in a shapefile (located in a geodatabase and otherwise).  My workflow in the past has been simple: Open the attribute table, add a new field if needed, just click the cell and enter text or numerical data, easy.  Now it appears to be locked?  When I click and type, no data.  I've tried setting up new test colums of different types, tried saving the shapefile outside of a geodatabase, ensured that they are not "read only"--All to no avail.  It's driving me crazy and I'm hoping someone has some advice for what seems to be a really basic function that no longer works! Attaching screenshot of the field that currently shows all null values
ChristianNoack
Mine does! It says "This layer is being projected on the fly"
I'm guessing it won't edit because it's a different projection than the map?
Scott_Harris
That shouldn't prevent edits from being made, even though it's a best practice to edit in the same coordinate system as the data.
KeithAddison1
One possible cause is the layer to be edited not having a coordinate system defined.
XiclalyMagdaleno
Hi everyone! If double clicking the cell within the attribute table doesn't activate field to edit, try selecting the column and press F2. After a minute or so, the lock on the cells returns so you may need to repeat the process as needed.
