Can I safely clear out XML files from ArcToolBox History folder?
3003
09-19-2022 04:43 PM
DarrenConly
Greetings All,
I'm doing a clean-out of my drive and noticed I have over 5GB of XML files in the following folder:
Can I delete these without hurting anything? Should I delete through the File Explorer or can I do so through Arc Pro?
Thanks!
DanPatterson
MVP Esteemed Contributor
Here are your candidate environments accessed via arcpy.
I work on one machine, using locally stored data, so yours will differ.  I have nothing in the ...  Appdata\ Roaming ... folder at all
import arcpy
environments = arcpy.ListEnvironments()
environments.sort()
for environment in environments:
    # Format and print each environment and its current setting.
    # (The environments are accessed by key from arcpy.env.)
    print("{0:<30}: {1}".format(environment, arcpy.env[environment]))
MDomain                       : None
MResolution                   : None
MTolerance                    : None
S100FeatureCatalogueFile      : None
XYDomain                      : None
XYResolution                  : None
XYTolerance                   : None
ZDomain                       : None
ZResolution                   : None
ZTolerance                    : None
addOutputsToMap               : True
annotationTextStringFieldLength: None
autoCancelling                : True
autoCommit                    : 1000
baDataSource                  : None
baNetworkSource               : None
baUseDetailedAggregation      : False
buildStatsAndRATForTempRaster : True
cartographicCoordinateSystem  : None
cartographicPartitions        : None
cellAlignment                 : DEFAULT
cellSize                      : MAXOF
cellSizeProjectionMethod      : CONVERT_UNITS
coincidentPoints              : MEAN
compression                   : LZ77
configKeyword                 : None
extent                        : None
geographicTransformations     : None
gpuId                         : 0
isCancelled                   : False
maintainAttachments           : True
maintainCurveSegments         : None
maintainSpatialIndex          : False
mask                          : None
matchMultidimensionalVariable : True
nodata                        : NONE
outputCoordinateSystem        : None
outputMFlag                   : Same As Input
outputZFlag                   : Same As Input
outputZValue                  : None
overwriteOutput               : False
packageWorkspace              : C:\Users\dan_p\AppData\Local\Temp
parallelProcessingFactor      : None
preserveGlobalIds             : False
processingServer              : None
processingServerPassword      : None
processingServerUser          : None
processorType                 : None
pyramid                       : PYRAMIDS -1 NEAREST DEFAULT 75 NO_SKIP NO_SIPS
qualifiedFieldNames           : True
randomGenerator               : 0 ACM599
rasterStatistics              : STATISTICS 1 1
recycleProcessingWorkers      : None
referenceScale                : None
resamplingMethod              : NEAREST
retryOnFailures               : None
scratchFolder                 : C:\Users\dan_p\AppData\Local\Temp\scratch
scratchGDB                    : C:\Users\dan_p\AppData\Local\Temp\scratch.gdb
scratchWorkspace              : None
scriptWorkspace               : C:\Users\dan_p\AppData\Local\Temp
snapRaster                    : None
terrainMemoryUsage            : False
tileSize                      : 128 128
tinSaveVersion                : CURRENT
transferDomains               : False
transferGDBAttributeProperties: False
unionDimension                : False
workspace                     : None
you might want to look at
GetLogHistory—ArcGIS Pro | Documentation
and
SetLogHistory—ArcGIS Pro | Documentation
GetLogMetadata—ArcGIS Pro | Documentation
and
SetLogMetadata—ArcGIS Pro | Documentation
it looks like it can be shut off
... sort of retired...
DanPatterson
Analysis tab, left most tool on 2nd row... aka History.... click it.
Select and delete all that you don't want.
Check your options in Project, Options
DarrenConly
Hi @DanPatterson, Thanks for quick reply.
Referring to your Options screenshot, I confirmed that the "log to XML" box is un-checked.
Based on a test, the XML files appear to get created when I run a python script that uses arcpy outside of Pro, e.g., when I run through VSCode or some similar interpreter. Specifically, when I ran a script via VSCode, it made a new XML file, but when I ran the same script via a Pro toolbox, it didn' t create an XML file.
So it seems like running arcpy script outside of Pro creates the XML file? I wonder if there's some env parameter you can set in the script to prevent creation of XML files?
DanPatterson
import arcpy
environments.sort()
MDomain                       : None
MResolution                   : None
MTolerance                    : None
XYDomain                      : None
XYResolution                  : None
XYTolerance                   : None
ZDomain                       : None
ZResolution                   : None
ZTolerance                    : None
autoCommit                    : 1000
baDataSource                  : None
cellSize                      : MAXOF
compression                   : LZ77
extent                        : None
gpuId                         : 0
isCancelled                   : False
mask                          : None
nodata                        : NONE
outputZValue                  : None
snapRaster                    : None
tileSize                      : 128 128
workspace                     : None
and
and
DarrenConly
Thanks Dan!
Adding arcpy.SetLogHistory(False) made it so the script no longer creates XML files.
The method for listing environment settings is also useful.
Cheers,
