Can I label only selected features
3526
08-21-2025 05:46 PM
joecastellana
Hello all,
I have set up a map with related records between three tables. When the user selects the features they want and zoom to the area, I only want selected features to show their labels as the map gets too cluttered/confusing when all other features are labelled.
Can I set up a label class only for selected features? Or is there a property I can use that only applies to selected features?
Thanks.
BarryNorthey
Label selected features in ArcGIS Pro might provide an option.
joecastellana
Thanks Barry, that looks like what I am after.
When I follow the steps to create annotation feature class, the option "Link the annotation to the following feature class" is inactive but does not give any reason or warning.
JesseWickizer
Link the annotation to the following feature class may be inactive if you're using basic license level at version 3.4 or lower. At version 3.5 however, feature-linked annotation is available at all license levels.
JesseWickizer
There's not a direct way limit the labels in a layer to only selected features, but here are a few workflows to consider.
1. Convert features to annotation or graphics. These tools convert only the selected features to annotation or graphics.
2. Create a selection layer from the selected features and turn on labeling for that layer only. When the layer has a selection, right-click the layer > Selection > Make Layer From Selected Features. This layer doesn't dynamically update as the selection changes so you'd have to make a new selection layer to label a different set of selected features
3. Add a "labeled" attribute to the feature class to define which features are labeled. Configure a SQL query on the label class to only include those whose "labeled" field equals 1 (or however you want to define it).
When you make a selection, update the "labeled" field for the selected features and they will be included in this label class.
You could create a model that does the following 3 operations so every time you want to label a different set of features, just double-click the model and it will update the dataset so only the selected features have the '1' value in the 'labeled' field.
  • Calculate Field (field name = labeled, expression = 1)
  • Select Layer By Attribute (Selection Type = Switch the current selection)
  • Calculate Field (field name = labeled, expression = 0)
