Can I create 2 relationship classes between the same 2 feature classes?
991
08-15-2023 05:09 AM
StevenBradbury1
I am looking to create 2 relationship classes so that the values from one field will show up in a Field Maps form for feature class. I have two feature classes (Blocks and audit points). I currently have one relationship class which functions to show the values from a field in the blocks class to show up on the attribute forms for the audit point class. When I attempt to create a second relationship class to show an additional field in the form, it works, however it seems to cancel the other relationship as the other relationship field is blank.
Is there a way to have two relationship classes function simultaneously?
If not, is there some other work around to have two relationships show up in a Field Maps form?
