Calculations in one field
1394
02-28-2024 12:17 AM
HusamJubeh
Hello all
I have four calculations, the final result of which is the field value.
Can you help me write it in Python 3?
A = abs(!AREA_RECORD! - !Shape_Area!)
B = 0.8*math.sqrt(!AREA_RECORD!)+0.002* !AREA_RECORD!
C= abs(B- A)
D = B - C
print D
Thanks
Tags (1)
GeeteshSingh07
Hope this helps,
If you're running this in 'Calculate Field', this will be the format. In Code Block,
import math
def calculate_D(AREA_RECORD, Shape_Area):
    A = abs(AREA_RECORD - Shape_Area)
    B = 0.8 * math.sqrt(AREA_RECORD) + 0.002 * AREA_RECORD
    C = abs(B - A)
    D = B - C
    return D
Expression:
calculate_D(!AREA_RECORD!, !Shape_Area!)
For example,
Reference: https://pro.arcgis.com/en/pro-app/latest/tool-reference/data-management/calculate-field-examples.htm
Best Regards,
Geetesh
[email protected]
GeeteshSingh07
Hope this helps,
import math
    C = abs(B - A)
    D = B - C
    return D
Expression:
For example,
Best Regards,
Geetesh
[email protected]
HusamJubeh
Thank
