Calculating population in a polygon from a raster
489
01-26-2026 02:15 PM
AlexD1
Hi all
I am trying to calculate the population within a polygon (SA2 in Australia) from a population grid with a 1 km2 resolution. I don't want the grid value to be double counted when the raster intersects more than one polygon, which I believe excludes zonal statistics. I understand the assumptions with population distribution within the raster cells (eg evenly distributed) but I am having trouble even getting to a point I can do the calculation to get the SA2 populations.
There are a couple of methods I have tried, but none seem to be working as I expected.
Firstly, turning the raster into points (vector), then summing the points in each polygon. When I use the raster to point tool, not all raster cells convert to points.
Secondly, when I convert the raster to a polygon (gridded vector) to do an area weighted calculation, a lot of the boundaries dissolve so rather than having a 1x1 grid of polygons I have a map where some polygons are 1x1 and others are completely random shapes. Where boundaries have dissolved, they only get the base value of the raster (e.g. if 2 raster cells were each 2 and combined into one polygon, the polygon has a value of 2 rather than 4).
Open to other ideas too if anyone has them!
Thanks
Alex
DanPatterson
MVP Esteemed Contributor
Raster to Point (Conversion)—ArcGIS Pro | Documentation
did you follow the instructions to ensure that the extent parameter is set to avoid resampling and perhaps shifting?
If you have a visual of where cells were not converted to points, that would be useful.
for Zonal statistics
How zonal statistics tools work—ArcGIS Pro | Documentation
did you follow the discussion and comments about cell size, snap raster and cell alignment for zonal statistics?  It may be the cause of some of your issues
... sort of retired...
JonathanDelura
For Zonal Statistics, the value of a raster cell is only caclulated for a zone if it's center is within that zone, so as long as the SA2 polygons don't overlap, there shouldn't be any double counting.
