Hey All,
I am working in model builder to build polygons based on a set of points. So far I have the polygons being created successfully and have added a few fields I need to have populated. The data I need to have placed in the new fields is contained in the iterated layers. The iterated layers however are point data how can I get the values from one of the points and use that to populate the new fields in the polygon?
Hey @FlightDeck, thought about a few different options here..
I think testing spatial join will be a good starting point to see if this deliveries what you require.
Hey @FlightDeck there might be a range of different ways to achieve this although it may depend on values you require to be added to the new polygon. Couple of questions.
@BrendanNewell the first 2 fields I need are a text fields and are the same within the field and as such obtaining the value from any point would be acceptable. The next 2 fields are numbers so it would be best if I could grab the highest value available from each field.
