Calculating change of slope angle within given slope interval using ArcGIS Pro
1198
03-14-2022 11:26 PM
mursalahmed
I need to find areas of rapid slope change greater than 10º within a slope interval of 28º < slope < 55º.
I created a slope layer from the DEM and then CON (spatial analysis) to isolate the areas 28º < slope < 55º.
Would the next step be to run SLOPE on the CON output layer, effectively getting the slope of the slope (i.e. the changes in slope between adjacent cells)?
Then running a RASTER CALC to isolate areas of slope change >10º?
I'm using ArcGIS Pro version 2.9.1
DanPatterson
MVP Esteemed Contributor
SMangum
Interesting! That's exactly what I posted on StackExchange 😉
I'm going to use the approach suggested by @DanPatterson.
Good luck with your project!
