Hello,
I need to create a new raster layer which shows from where an observer can see at least the top of a communication tower. I am familiar with the Visibility tool, however it seems like there is a significant factor missing from its analysis.
One can specify a single elevation raster layer for Visibility's calculations - typically a DEM or a DSM. It seems that for a true analysis of visibility, one would need to use both a DEM and a DSM of the area. Here's why...
An observer, perhaps 2m tall, would have to stand upon the bare-earth DEM, then look toward the tower, which also stands upon the bare-earth DEM. The catch is that there may be bare-earth obstructions and/or vegetation or man-made structures between the two locations. All of these potential obstructions are included in the DSM layer.
The Visibility tool could be much smarter - and create a much more realistic analysis - if both the DEM and DSM data are used in the analysis.
Does that make sense? Is there another way to work through this with current ESRI tools? Should Visibility tool be beefed up?
Thanks for your thoughts and time.
Regards,
-Gary
