Calculate field with Code Block doesn't work
2231
11-14-2022 01:44 PM
JulietteLapeyre
I am trying to calculate a field in a model builder, using if statements.
In the 'Calculate Field' window, I create a new attribute 'perturbateur' (string)
the formula to calulate this attribute refers to a code Block below, which shows no error. But I only get null values.
perturbat=
computeType(!FID_Buffer_coupes_Dissolve!, !FID_Reboisement_Dissolve!)
Code Block
def computeType(fid_c, fid_r):
    if fid_c== 1 and fid_r==1:
        perturbat = 'coupe et reboisement'
    elif fid_c== 1:
        perturbat = 'coupe'
    elif fid_r==1:
        perturbat = 'reboisement'
Could you help me understanding what is wrong ?
DanPatterson
you put in two elif checks but you don't cover the case where 0's appear.
More importantly, your def doesn't have any 'return' statements.
Your Arcade expression basically does an else if both are equal to 1, or the first doesn't equal 1. so to backtrack on your python code it would be
    if (fid_c == 1) and (fid_r==1):
        return 'coupe et reboisement'
    elif fid_c == 1:
        return 'coupe'
    return 'reboisement'
But I would check if you want fidc to return 'coupe' if it equals 0?  So play around with the possible combinations and what you actually want returned for all the cases of the two fieds ,,,, ie,
1  1
1  0
0  1
0  0
... sort of retired...
JulietteLapeyre
It works with Arcade, but I am still interested in knowing how to do with Python3
if ($feature.FID_Buffer_coupes_Dissolve==1 && $feature.FID_Reboisement_Dissolve==1) {
else if ($feature.FID_Buffer_coupes_Dissolve==1) {
    return 'coupe'
else {
DanPatterson
    elif fid_c == 1:
        return 'coupe'
1  1
1  0
0  1
0  0
JulietteLapeyre
It works great, thanks DanPatterson!
