Bug creating features in a Shapefile
916
02-13-2024 07:36 AM
cdanielvarons
Hello, I want to report a problem:
Sometimes when a polygon is created in a shapefile layer and not in a geodatabase, the element disappears from the map but its properties are saved in the attribute table. I use ArcGIS Pro 3.2.
(view in My Videos)
Robert_LeClair
Esri Esteemed Contributor
Hmmmm...that's very strange.  I mimiced the workflow that you had in your video with zero errors.  Sometimes when I see strange behavior like this, I rename the Esri folder in two locations to ESRI__OLD.  Those locations are:
C:/users/<user_profile>/appdata/local
C:/users/<user_profile>/appdata/roaming
Does the issue persist?
