Buffer tool creates miltipart features as default
66
14 hours ago
JamesCarroll7
Hi all,
I updated ArcGIS Pro this morning to version 3.6.0, and now all of the features that get created when I use the Buffer tool are multipart features.
I have a feature class which has 4 land parcel areas in it and I used the Buffer tool to put a 40m buffer around these land areas. The Buffer tool created the 4 buffers as normal, but when I tried to select one of the buffer areas it instead selected all 4 areas instead of just the one area. After looking on Google, I used the Multipart to Singlepart tool to solve the problem and make each of the buffer areas individually selectable.
I don't see why this is happening. Is it a bug or is it a feature of the new ArcGIS update? It seems like a real step backwards. Is there a way to turn this off? I don't know if this is happening with any other tools as I have only used the Buffer tool so far. Any help is appreciated as always.
CodyPatterson
MVP Regular Contributor
Hey @JamesCarroll7
Would you be able to send a screenshot of what you see in terms of the options and different check boxes you used? In 3.5, this could be different, but there is a setting for "No Dissolve" which should prevent it from being multipart:
Cody
