Batch Update Data Source in Pro Map - python/CIM
3213
12-22-2022 10:45 AM
ZacharyUhlmann1
I recall unsuccessfully traversing this topic a couple months ago (did not post here though).  Simple question.  I have multiple layers in an ArcGIS Pro map.  I have created an updated feature class WITHIN the same gdb, but with a different name.  Currently I have 15 layers utilizing the same data source path/to/zachs.gdb/fc_name to path/to/zachs.gdb/fc_name_v2note that the 15 layers have definition queries for 15 different value. I have found the documentation on how to use the cim to change the dataset or gdb underlying the source, but NOT if there is simply a different FC in the same path/to/gdb/<dataset>.
BELOW code adapted from here (https://pro.arcgis.com/en/pro-app/latest/arcpy/mapping/updatingandfixingdatasources.htm) BUT there are no methods or properties in the CIM or elsewhere to update my FCs if it's just a name change.  Ideas? Can be with CIM or any module...
p = arcpy.mp.ArcGISProject('current')
m = p.listMaps('zachs_map')[0]
l = m.listLayers('group_w_15_layers')[0]
layer1 = l.listLayers()[1]
layer1_cim = human.getDefinition('V2')
dc = layer1_cim.featureTable.dataConnection
dc.workspaceConnectionString
thanks!
Zach
Pro V. 3.0.02
Tags (3)
RhettZufelt
MVP Notable Contributor
Looks like update connection properties will do that for you.
I'd start with the first example under "Using the connectionProperties dictionary".
R_
RhettZufelt
R_
ZacharyUhlmann1
You are 100% correct.  I always confuse database and dataSET.  Took me some fumbline, but eventually...Thanks @RhettZufelt !
# Update the Feature Classe(FC) source in TOC via the CIM
# In this example, multiple Layers nested in Group Layer, all same source,
# with Def Queries to make different.
import copy
m = p.listMaps('map_name')[0]
# Get Layer Group from TOC containing the species layer
spp_group = m.listLayers('spp')[0]
# Now get list of all layers
spp_lyrs = spp_group.listLayers()
# loop through and update layer source FC to species_v2
for spp in spp_lyrs:
    cp = spp.connectionProperties
    cp['dataset']='species_v2'
    spp.updateConnectionProperties(spp.connectionProperties, cp)
