Batch Geoprocessing Tools
1623
08-29-2018 11:40 AM
DemetrusLeFlore
I have been using some of the geoprocessing tools in Pro and notice that the batch mode is unavailable. I searched and found the "Batch geoprocessing" topic in the online help section and followed the instructions but find that the batch mode for several common tools, such as clipping and geocoding, is not even an option.
Has anyone else had this issue? If so, is there a solution?
Tags (1)
ThomasColson
What version of ArcGIS Pro are you using?
DemetrusLeFlore
It appears to be 2.0. I see that the batch processing was made available in version 2.2?
ThomasColson
Yes, so that is why you are not seeing the tool, but are confused by the online documentation. Be sure to add your vote and use case to this very confusing issue at https://community.esri.com/ideas/15059.
DemetrusLeFlore
Good idea. yes vote from me.
deleted-user-qpvAI3Fo0MKR
That's correct, Demetrus LeFlore‌; batch geoprocessing is available in 2.2 and above:
