BAO to ArcGIS Pro Labeling
825
07-13-2017 11:37 AM
RachaelChasse
Hi Everyone,
I'm using data created in a BAO project in an ArcGIS Pro map.  The site layer draws fine, but within PRO I can't add a custom field to this layer.
As a result, I used AGOL to add the field.  This field shows up on the attribute table correctly when in ArcGIS Pro, but when I try to create labels from it none of them show up on the map.
Has anybody experienced this and know of a solution?  I did check that labels were turned on, and selecting a "BAO generated" field to label with worked fine.
Thank you!
Tags (3)
