Bad performance in ArcGIS Pro
10779
22
02-26-2024 02:43 AM
red
I'm using ArcGIS Pro in the newest version on a Dell Precision 3571 Laptop with Intel i7 12700H CPU, 64GB RAM and Nvidia T600 graphics.
I think the technical specs of my device are not so bad but the performance of ArcGIS Pro is not good at all. In my project there are about 20 layers, all in the same gdb with the same coordinate system. I'm switching between two or three background maps (OpenStreetMap layer included in Pro and other WMS services). I have quite a few text fields in the map and have three or four layouts open.
Even simple tasks like changing the color of a polygon take several seconds. Also other stuff like field calculations in the attribute table or selecting objects by attribut take longer than I think they should. Moving a text field also takes some time.
In the past I've used ArcMap on much older hardware but the performance for similar tasks was much, much faster.
Am I using the wrong hardware? What can I do to improve the performance?
Regards
Robert
red
Thanks, I will try that.
Bud
Legendary Contributor
red
I already tried disabling most of what is listed there. It didn't help much.
RhettZufelt
MVP Notable Contributor
I just thought that was expected.  The things you list always seem to run faster in ArcMap than in any version of Pro that I have tried.
R_
by Anonymous User
Not applicable
Eugene_Adkins
I mentioned the location of the data it in case @red was new to Pro. It's something I learned the hard way. Sometimes the performance can be improved by discovering a "legit" bug. BUG-000153703 (which was thought to only be related to the parcel fabric network) is a good example. It made Pro impossible to use when it came to basic functions and edits due to slowing response and performance, but it was fixed in a later release. It took me a long time to get that bug identified with tech support. As you implied, it's frustrating.
red
This is not very encouraging. I was hoping there is something I can do. Maybe a high performance PC with great cooling and dedicated high performance graphics or something like that...
red
I've run the "ProPAT and PerfTools v16" and got these results:
Level 1: 2.982
Level 2: 5.924
Level 3: No spatial analyst license
I thought I would be able to compare this to other peoples results but I can't find anything. Are these results good or bad?
AlexanderDanielPratama
That's quite impressive you have. I'd like to help you since my office laptop and home PC are fast enough for ArcGIS Pro. My office laptop is ASUS ROG G16 (SSD NVME, 32 RAM, NVIDIA RTX 4050). Just want to clarify, are you using NVME in your C-drive. Then, does your Nvidia feature active to accelerate your ArcGIS Pro?  I do not have experience using gpu workstation, for common or gaming gpu usually it enough for desktop
AlexanderDaniel_Pratama_0-1709029058484.pngAlexanderDaniel_Pratama_0-1709029058484.png
Usually in my case, if the NVIDIA runs the ArcGIS Pro performance is quiet good when rendering the data and editing the feature class.
Hope, it helps you
Cheers
Bud
Are you using a VPN?
A colleague mentioned:
I suspect that it’s the VPN connection that slowed your testing down, rather than the specs of the Laptop (and improved specs wouldn’t really help here). That’s been my experience with my Laptop: ArcGIS Pro performs adequately in the office, but is significantly slower when working remotely over a VPN.
GIS applications are very network traffic-intensive. So when that data needs to move over the internet as it does with a VPN connection, the performance can degrade significantly.
The widely accepted solution for Work From Home GIS use is to connect remotely to a computer on the network (through a remote desktop program) and perform the GIS tasks there, rather than working over VPN. That way only display and inputs are being transmitted back and forth, not the data.
There are some other suggestions to improve ArcGIS performance over VPN, but most aren’t practical or entirely effective:
  • make a local copy of the data so it isn’t transmitted back and forth through the VPN connection
  • publish feature services and connect ArcGIS Pro to the feature services, rather than directly to the data in the GIS db (not practical to publish services for all the data that you would need to view/edit)
  • turn off ArcGIS Pro indexing (you’ve already tried this)
  • use ArcMap instead since it’s somewhat faster over VPN 🙂 older suggestion that isn’t viable much longer)
Sources:
