Average distance from point to polygon
1366
05-18-2021 08:08 AM
Labels (2)
Ruben
I have a polygon layer of all the municipalities in the Netherlands and a point layer of all restaurants of a specific franchise. I want to calculate the average Euclidean distance to a restaurant for every single municipality. So every municipality would get a value of X meters which indicates the average Euclidean distance that an individual would have to travel to reach a restaurant when residing in the specific municipality. How would I go about doing this?
Thanks in advance,
Ruben
DavidPike
MVP Notable Contributor
I would probably generate evenly dispersed points within each municipality (e.g. every 100m) and then a spatial join to add the munipality name or ID to the points.
Then generate a near table Generate Near Table (Analysis)—ArcGIS Pro | Documentation or use Near analysis  to find the distance to the closest location per point.  I would make sure that the find only closest feature parameter is set so that you don't generate a gigantic table.
for each set of municipality points just calculate the median value.
This of course also assumes that population is evenly distributed within the municipality.
DavidPike
