Avalanche Hazard Mapping without vegetation
1966
03-11-2022 12:14 AM
SMangum
I need to find the slope areas A) between 28º and 55º, B) contain an abrupt change of more than 10º, C) are more that 625 m2 in area, and D) are adjacent to glaciers
VERSION: ArcGIS Pro 2.9.2
INITIAL LAYERS: DEM_Slope, Glaciers_Raster
This is the workflow I have put together:
Slope Interval (28º to 55º):
  1. CON: conditional raster=“DEM_Slope”, where value is greater than 28 AND value is less than 55, true raster=“DEM_Slope” -> Con_Slope28to55
Slope Change (>10º):
  1. DIF: “DEM_Slope”, "Con_Slope28to55" -> Diff_SlopeMax_ConSlope28to55
  2. CON: conditional raster=“Diff_SlopeMax_ConSlope2855", WHERE value is greater than 10, true raster="Diff_SlopeMax_ConSlope2855" ->  Con_DiffSlopeMaxCondSlope28to55
  3. RECLASSIFY: I don't know how to reclassify to prep layer for Raster to Poly featuring only slope interval 28<slope<55 combined with slope change >10º -> Reclassify2_SlopeMaxConSlope28to55
  4. RASTER TO POLYGON: "Reclassify2_SlopeMaxConSlope28to55" -> RastToPoly_SlopeIntervalSlopeChange
Large Surface Areas (>625 m2)
  1. CALCULATE FIELD: area
  2. SELECTION: areas>625 m2
Close to Glaciers:
  1. EUCLIDIAN DISTANCE: "Glaciers_Raster" -> EuclidDist_Glaciers
  2. RECLASSIFY: "EuclidDist_Glaciers" with 2 classes=[0-200 (5); 200-50282.359375 (1)]  -> Reclassify2_EuclidDistGlaciers
  3. RASTER TO POLYGON: "Reclassify2_EuclidDistGlaciers" -> RastToPoly_ReclassEuclidDistGlaciers
Finalize:
  1. CLIP: "RastToPoly_SlopeIntervalSlopeChange", "RastToPoly_ReclassEuclidDistGlaciers"
Is this workflow OK? What mistakes am I making? Should I try a RWO approach instead? THANKS!
DanPatterson
MVP Esteemed Contributor
see you other thread Calculating slope change - Esri Community
... sort of retired...
DanPatterson
Results? Do they make sense? or did you get any errors?
During the process were the cell sizes the same?  snap raster? extent?
Environment parameters will have an effect on processes and output
SMangum
Hi Dan,
I'm thinking about trying a different approach. See the following post in ArcGIS Pro Questions:
1153652
DanPatterson
profile or plan curvature?
Curvature (Spatial Analyst)—ArcGIS Pro | Documentation
SMangum
Huh! I think that's exactly what I need. You're a genius!
If I understand correctly, the input raster would be my DEM_Slope raster. Or am I confused here?
And what constitutes noisy data and how do I know if I have it? High resolution?
My cell size is 10mX10m. Is that high resolution? And if so, should I try the SURFACE PARAMETERS tool instead?
DanPatterson
