AutoCAD Layer to Geodatabase
1122
08-26-2020 12:48 PM
TylerTownes
Is there a tool for importing a specific AutoCAD layer (and not the whole drawing) into a ArcGIS Pro file geodatabase?  Thank you.
Tyler
ArcGIS Pro 2.6.0
Tim_StærkFendrich1
I don't think so.
You could use the Data Interoperability Extension for this (If you have it).
Or you could choose Add Data, browse into the CAD file and select the geometry type, add it, and put a definition Query on the Layer field.
In all other cases, I think you need to import everything into a temporary geodatabase and then select what you need using a filter on the Layer field.
TylerTownes
Thank you.
