Auto - Generate Bookmarks
4518
7
07-06-2021 05:19 AM
GaryBarden
Is there a way to auto-generate bookmarks based on a series of point features? I have a layer with about 200 points. I’d like to auto-generate a bookmark for each site at the same zoom scale.
AubriOtis
I'm not sure about auto-generating bookmarks, but if you want to create a layout and add the map to it you can then create a spatial map series with the extent set to center and maintain scale. A new page will be generated for each point and you can quickly move between pages. Learn more here: https://pro.arcgis.com/en/pro-app/latest/help/layouts/create-a-map-series.htm
Cheers,
Aubri
GaryBarden
Thanks. I'm familiar with creating a map series...what I'm working toward requires bookmarks...thanks for the thought.
MicZatorsky_AEC
JoeBryant1
The searches above just confirm that this function does NOT currently exist.
I went ahead and added this to the ArcGIS Pro Ideas. PLEASE UPVOTE!
Generate Bookmarks from Features
RandyMcGregor_BMcD
Maybe I'm hallucinating, but I thought you could add bookmarks from features in ArcMap, and I did it a LOT. You often need to zoom from feature to feature and bookmarks are a lot more efficient for that than select, zoom to, repeat...
JohannesLindner
I implemented this functionality in a Toolbox: https://community.esri.com/t5/arcgis-pro-questions/create-bookmarks-from-features/m-p/1299420
Have a great day!
Johannes
RandyMcGregor_BMcD
This is great. Thank you for creating and sharing it!
