Layer to Bookmarks Tool & Bookmarks to Layer Tool
4428
8
02-08-2011 03:20 AM
Status: Open
MōnoSimeone
The ability to create bookmarks from an input feature class with the option of a buffer distance (specifically for point features).
Why should I click on each feature to create the bookmark?
The ability to create a polygon feature class of the extent of bookmarks - the ability to select the whole list or only certain bookmarks.
Would be useful for data-driven pages (DDP) use.
Ideally, I'd like to see a GP-toolbox for spatial bookmarks with above functions.
8 Comments
StevenBowley1
Would be great to auto create a series of bookmarks in an MXD based on the extent of selected polygon features in the map, or by passing the tool a polygon layer.   Maybe this can already be done?
JenniferBorlick
Depending on what you wanted to do with them, you could probably do something with Data Driven Pages as a work around.
TheoFaull
good idea for helping create data driven pages. espcially for those who are scared of python codes!
by Anonymous User
This is an older idea, but still a very good one. Even being able to create bookmarks from a feature class via arcpy mp would be awesome. A tool would be even better. I was looking for a way to do this today and there doesn't seem to be one.
JoeBryant1
Creating bookmarks for many features is time consuming and very repetitive. A spatial map series will not work for the web map workflows I want the bookmarks for (many ArcGIS apps rely on bookmarks). This should work with features of points, lines or polygons.
The tool would follow the workflow:
1) Select a single feature in a feature class
2) Zoom to and center on that feature
3) Create a bookmark on that extent
This tool would iterate through the feature class (honoring any definition queries), creating a bookmark for each record.
The bookmark could be named after an attribute in the current record from a defined field, or just an incrementing number.
Optionally, this process could select multiple records with a matching value in a defined field and zoom to the extent of the matching features to create the bookmark.
JohannesLindner
I took a stab at implementing this myself, the script and tool can be found here:
https://community.esri.com/t5/arcgis-pro-questions/bd-p/arcgis-pro-questions
Bud
It has been 4,843 days since this idea was submitted. With lots of upvotes. Can Esri comment?
CarolineBlack29
Esri please implement this! Would be great for web maps not just pro!
