Attribute table gets stuck and greys out while reloading
1256
11-26-2024 06:47 AM
Sergej_Fährlich
Hello,
a common "error" when using Arcgis Pro (V 3.2.49743) seems to be that attribute tables do not reload properly when I edit layer. When I merge or separate polygons for instance, the attribute table reloads to update its data. It frequently happens that this update process gets stuck and the table stays grayed out. Then I have no choice but to close the table and open it again. However, since this happens quite a lot when you edit a lot of data, this is very annoying.
Screenshot
LRMInfoSection
does this happen across all datasets you're working on? Maybe you could test making the same changes from a local drive if it's on the network / hosted, to rule out that being an issue.
Sergej_Fährlich
Well it looks like it has indeed something to do with the way our server network processes our data. I stored all data on my local PC and it worked fine.
Debert
I've been troubleshooting this issues for 4 months now.
Specifically, while editing a shared hosted feature layer in ArcGIS Pro 3.5.2.
If I open the attribute table and scroll to the end- it greys out and spins for 8-15mins before finally gathering the table information.
ArcGIS Pro is stored on my local drive.
Anyone else experience this?
I am the GIS Coordinator for Iowa Regional Utilities Association.
Find me on Linkedin.
