Attribute Table Edits Not Staying
684
02-10-2026 02:32 PM
RhondaWalden
I am trying to edits fields in a road attribute table. I update the ranges for a section of road, select the next range to edit it, the screen flashes and then my corrected ranges revert back to what they were. I have been doing this same process for months and have not noticed this issue. I did an update to ArcPRO yesterday. Anyone else have this problem?
Eugene_Adkins
Have you tried making an edit in the attribute pane instead of the attribute table to see if the edit remains?
MichaelVolz
Esteemed Contributor
What version of Pro are you at now and what version were you at before the upgrade?
Can you access a different machine with older Pro version to see if the problem exists there?
ErikRose
Do you have any Attribute Rules set up for this layer?  If an attempted edit would violate an attribute rule, this could cause the data to revert back on failure.
AlyciaRajendran_esri
Hi Rhonda,
Sorry this is happening. Which version of Pro did you just upgrade to, 3.6? Would it be possible to record your screen and share it with me?
Thanks!
Alycia
AlfredBaldenweck
MVP Frequent Contributor
How are you "committing" the edits? Do they stick if you use the "Enter" key?
