Attribute Rules - function similar to Prompt from Attribute Assistant?
1702
09-23-2019 05:51 AM
JulieRoebotham
I am doing a presentation on common attribute assistant workflows and whether or not they can be replicated using attribute rules in ArcGIS Pro. we have managed to perform most of the workflows we are testing, but aren't having any luck replicating the PROMPT method in ArcGIS Pro using Attribute Rules.
Does anyone know if this functionality exists in Pro - either using Attribute Rules or by some other reasonably similar way? thanks!
JulieRoebotham
In case anyone is looking for the answer, the prompt functionality is a capability of the feature template itself, and you can set up a rule to warn a user that that field hasn't been populated.
JulieRoebotham
