Attribute Rules: Copy parcel number to address point when new address point created?
2353
09-14-2022 04:39 PM
avonmoos
I need assistance building an expression which would copy the parcel number attribute from our parcel layer to the parcel attribute in our address point layer when creating a new one. This would be based on the parcel that the address point being created sits on.
JohannesLindner
Create a Calculation Attribute Rule for your point feature class (SiteAddress).
As field for the rule, choose "BaseParcel"
As triggers, choose "Insert".
As expression, use this:
var parcels = FeatureSetByName($datastore, "SurveyParcel", ["ParcelID"], false)
var intersecting_parcel = First(Intersects(parcels, $feature))
if(intersecting_parcel == null) {
    return null
return intersecting_parcel.ParcelID
This should work if you're working in a file geodatabase. If you work in an Enterprise geodatabase, you have to replace "SurveyParcel" in line 1 with the complete name of the feature class ("Databasename.Dataowner.SurveyParcel").
Have a great day!
Johannes
JohannesLindner
As you're asking this in the ArcGIS Pro community, I'm assuming you mean Attribute Rules, not Assistant.
Introduction to attribute rules—ArcGIS Pro | Documentation
If you indeed mean Assistant, I'll move your question to the ArcMap community.
// Attribute Rule on the Address Points
// triggers: Insert
// load the parcels
var parcels = FeatureSetByName($datastore, "Databasename.Dataowner.Parcels", ["ParcelNumber"], false)
// intersect with the new point
// return null if no parcel was intersected
    return null
// else return that parcel's number
return intersecting_parcel.ParcelNumber
Have a great day!
Johannes
avonmoos
Thank you for the quick response! I'm pretty green when it comes to Arcade, below are the features and fields I will be using. Where in your code do I place these in the variables?
$feature.SurveyParcel
 and the parcel ID field is called ParcelID
$feature.SiteAddress
and the parcel ID field is called BaseParcel
JohannesLindner
    return null
Have a great day!
Johannes
avonmoos
Thank you 👍
