Attribute Rule
1151
08-07-2022 05:01 AM
UğurcanGül
I want to print the name of whatever column has changed in the layer with the attribute rule in a new column.
Sample;
I have a layer called Stops.
This layer consists of columns a, b, c, d.
I opened a new column named "e" to show the changed column.
When the user changes column a, b, c or d, I want to print the name of that column in column e.
Can u help?
JohannesLindner
Something like this could do what you want (not tested):
// Calculation Attribute Rule
// field: e (Text)
// triggers: Insert, Update, Delete
// write "INSERT" or "DELETE" into e
if $editcontext.editType != "UPDATE" {
    return $editcontext.editType
// define the fields you want to check
var checked_fields = ["a", "b", "c", "d"]
// build an array of fields where the value changed
var changed_fields = []
var old_attributes = Dictionary(Text($originalfeature)).attributes
var new_attributes = Dictionary(Text($feature)).attributes
for(var f in checked_fields) {
    var field = checked_fields[f]
    if(old_attributes[field] != new_attributes[field]) {
        Push(changed_fields, field)
// compare geometry
if(!Equals(Geometry($originalfeature), Geometry($feature))) {
    Push(changed_fields, "geometry")
// concatenate the field names into a string and write that into e
return Concatenate(changed_fields, ", ")
Have a great day!
Johannes
