Attribute Rule Intersects by subtype
1854
11-17-2021 07:56 PM
AaronCRose
I am wondering if it is possible to use the Intersects function at the subtype level instead of the feature level. I have a feature class with several subtypes and am trying to return an attribute value into the target layer. However, the attribute is picking up values from other subtypes of the same feature class. Is there a way to point the $datastore at a subtype of a feature or filter it by subtype code?
JohannesLindner
MVP Alum
var fs = FeatureSetByName($datastore, "FeatureClassWithSubtypes", ["*"], true)
// filter for subtype
// if you only care for a specific subtype:
fs = Filter(fs, "SubtypeField = 2")
// if you care for variable subtypes (different for each $feature):
var subtype = $feature.TargetSubtype
fs = Filter(fs, "SubtypeField = @subtype")
// intersect
var intersect_fs = Intersects(fs, $feature)
// return
if(Count(intersect_fs) > 0) {
  return First(intersect_fs).Attribute
return null
Have a great day!
Johannes
JohannesLindner
MVP Alum
// intersect
// return
return null
Have a great day!
Johannes
AaronCRose
Worked perfect! Thank you.
