Attribute Rule - Generate ID - Establishing Width
3363
6
02-15-2021 02:18 PM
by Anonymous User
Not applicable
In Desktop's old Attribute Assistant, you could create a generate ID rule that could keep a consistent width to the integer portion of the ID.  So you could have a width of 7 and if the sequence was only 3 numbers, it would add 4 zeros to the left.
I'm trying to  migrate a client from Attribute Assistant to Attribute Rules in Pro and I cannot find a way to accomplish this same functionality.  In the screenshot you can see how their IDs generated in ArcMap/Attribute-Assistant vs. how I can get them to generate in Pro using the following:
return "ADA-" + NextSequenceValue ("ADA")
where I've named the generated sequence "ADA"
What arcade can I add in to that expression to maintain that forced width?
JohannesLindner
Haha, I didn't even think of the Text() function...
Disregard the above, use this instead:
return "ADA-" + Text(NextSequenceValue("ADA"), "0000000")
Have a great day!
Johannes
MehdiPira1
Hi @Anonymous User ,
In ArcGIS Pro, click on the feature class layer you want to add attribute rules to in TOC and then click Data tab > Attribute Rules in Design.
In Attribute Roles windows you can add a Calculation Rule in Arcade like:
concatenate('ADA-000',$feature.<your fc field>)
I hope that helps.
Cheers
Mehdi
Please give a like if helpful and Accept as Solution if it's answered your query.
by Anonymous User
Not applicable
Hi! Unfortunately that won’t quite work as we need the integer length to stay at 7 regardless of if the next sequence value is three (999) or four (1000) integers lonv
MehdiPira1
@Anonymous User ,
Then you need to use something similar to this:
var ADA_id = split($feature.<your ADA field>, "-")[1]
If (Count(ADA_id ) == 4) {
   return concatenate('ADA-000',ADA_id)
else {
   If (Count(ADA_id ) == 3) {
      return concatenate('ADA-0000',ADA_id)
   else {
      return ADA_id
JohannesLindner
// next sequence value as string
var ada = "" + NextSequenceValue("ADA")
// there doesn't seem to be a while loop in Arcade,
// but we can fake one with a for loop...
for(var i = 0; i < 100; i++) {
  if(Count(ada) >= 7) {
    break
  ada = "0" + ada
return "ADA-" + ada
Have a great day!
Johannes
JohannesLindner
Have a great day!
Johannes
by Anonymous User
Not applicable
This worked perfectly!  Thank you!
