Attribute Rule Arcade Intersect and Copy Attribute from Feature A to B Error: Indexable type expected
2436
09-18-2024 07:42 AM
Ed_
by MVP Regular Contributor
Hello all,
Hope all is well, so i need some Arcade help 🙂
  • Let's say I have a point feature class which is empty and will be digitized via Field Maps.
  • The map will also contain a polygon layer ,and one of its attribute is say "attribute_ABC" and has values.
  • The point layer will also have attribute "attribute_ABC" which would initially be empty, so i am trying to create an attribute rule for it.
  • whenever the point intersects the polygon layer, it copies the respective attribute_ABC value from the polygon layer to the point layer attribute_ABC.
  • Basically the idea is to auto populate some of the attributes of the point feature class from other existing layers based on their intersection.
So I finally got the code working to the point that code block says that "Expression is valid" but when I try to add a point to the map, I get the following error
Error:
Failed to create Pt.
Failed to evaluate Arcade expression. [
Rule name: Poly,
Triggering event: Insert,
Class name: Pt,
GlobalID: {4E52CA0C-099D-4593-80AF-292A5CFE51CF},
Arcade error: Indexable type expected,
Script line: 11]
Code:
// Read the polygon layer
var poly =  FeatureSetByName($datastore, "poly");
// Intersect
var int = Intersects(poly, $feature);
// Check if there is an intersection
if (Count(int) > 0) {
// Get the first intersecting polygon's ABC value
   var firstPoly = First(int);
   return int.ABC;
 } else {
// if there's no intersection then retain the original ABC value or return null
   return $feature.ABC;
PS the map is being created in Pro 3.3.1 which will then published to AGOL and then that map will be used in Field Maps.
Question | Analyze | Visualize
KenBuja
MVP Esteemed Contributor
Line 10 should be
return firstPoly.ABC;
Ed_
@jcarlson @KenBuja @XanderBakker can any of you you please help?
KenBuja
Line 10 should be
Ed_
Good morning Ken, hope all is well 🙂
Yup that did it, thank you so much and have a great day!
