Assign data points to polygonal area
1013
01-26-2022 12:00 PM
Labels (3)
DavidKartsen
I've got a bunch of data points from a wifi speedtest 123 survey. I've placed those points into a map and want to organize their location. Each data points contains a question that asks what room number the test has taken place, so I want to assign/move those points to their respective rooms without manually placing all 200+ points.
AdrianWelsh
MVP Honored Contributor
It sounds like a Join would work here. If your polygons have a room number and if your data points have the same exact number, those should join up will.
https://pro.arcgis.com/en/pro-app/latest/help/data/tables/joins-and-relates.htm
https://pro.arcgis.com/en/pro-app/latest/tool-reference/data-management/add-join.htm
Though, the join is just tabular, however, you could make new data points from the centroid of each polygon after the join is completed.
KimberlyGarbade
Sounds like a job for Arcade and Batch Calculation Rules to me.
I wrote this in a text editor so its not code ready to run, but it should look something like this I think:
var intRoomNum = $feature.RoomNumber
var pntGeom = Geometry($feature)
var fcRooms = FeatureSetByName($datastore, 'PolygonFloorPlanCall', ["globalId", "RoomNumber"],true)
var ftJustOneRoom = filter(fcRooms, "RoomNumber = @intRoomNum")
if (ftJustOneRoom == null){
return pntGeom
} else {
return Centroid(ftJustOneRoom)
Here is a great link to something very similar:
https://www.youtube.com/watch?v=HFHJFCn2E1M
Hope this helps.
K
