ArcPy function to create new project
2202
01-27-2025 12:07 PM
YahyaMasri
I was wondering if there is a ArcPy function to create a new project from scratch given a root directory where I would want the project to be created.
CodyPatterson
MVP Regular Contributor
Hey @YahyaMasri
Here's a link to a similar post, would this work for you?
https://community.esri.com/t5/python-questions/arcpy-function-for-creating-a-new-arcgis-project/td-p...
The gist is to have a blank template project, and then copy that project to make a new blank one.
Cody
YahyaMasri
Thanks for the quick reply, Cody!
Is there no other way to create a new project if there is for example no blank template project? Thanks for the help and the link!
CodyPatterson
Hey @YahyaMasri
No problem! From what I've found, it doesn't appear to currently be a function within the documentation, I saw someone had mentioned a create() function, but that doesn't exist.
https://pro.arcgis.com/en/pro-app/latest/arcpy/mapping/arcgisproject.htm
Definitely suitable for an idea on the ideas forum!
Cody
DavidSolari
You can use the ConvertWebMapToProject function with a minimal map definition to get a project file in memory, which you can then save to disk:
z = arcpy.mp.ConvertWebMapToArcGISProject("""{
	"mapOptions": {
		"extent": {
			"xmin": -12933906.537,
			"ymin": 3993856.886,
			"xmax": -12933371.998,
			"ymax": 3994375.189,
			"spatialReference": {
				"wkid": 102100
	"operationalLayers": [],
	"baseMap": [],
	"exportOptions": {},
	"layoutOptions": {},
	"reportOptions": {}
}""").ArcGISProject.saveACopy(r"C:\path\to\project.aprx")
A bit hacky but it works. If you want a more comprehensive project as a base you're better off with @CodyPatterson's template method.
JoshuaBixby
MVP Esteemed Contributor
This is by far the best workaround currently available at Pro 3.5.  I will say, the minimum webmap definition needed to get ConvertWebMapToArcGISProject to work is:
{"mapOptions":{"extent":{}}}
