ArcPy Circle Function
1281
05-30-2024 11:33 AM
YahyaMasri
I am trying to create inset maps using ArcPy and I want them to be circles, but I don't know how to create a circular function the same way a rectangle function was up on the GraphicElement Documentation.
This is the code for a rectangle that was on the documentation:
def MakeRec_LL(llx, lly, w, h):
xyRecList = [[llx, lly], [llx, lly+h], [llx+w,lly+h], [llx+w,lly], [llx,lly]]
xyRecList = [[1,1],[1, 2], [2.75, 2], [2.75, 1], [1, 1]]
array = arcpy.Array([arcpy.Point(*coords) for coords in xyRecList])
rec = arcpy.Polygon(array)
return rec
p = arcpy.mp.ArcGISProject('CURRENT')
#Create a layout
lyt = p.createLayout(6, 3, 'INCH', 'New Layout with Rectangles')
Does anyone know how to replicate this process, but for circles instead?
RhettZufelt
MVP Notable Contributor
Not sure about layouts, but You can use the arcpy.analysis.buffer function to create circular polygons using a point and radius.
R_
DanPatterson
MVP Esteemed Contributor
def _circle(radius=100, clockwise=True, theta=1, xc=0.0, yc=0.0):
    """Produce a circle/ellipse depending on parameters.
    Requires
    `radius` : number
        in projected units
    `clockwise` : boolean
        True for clockwise (outer rings), False for counter-clockwise
        (for inner rings)
    `theta` : number
        Angle spacing. If theta=1, angles between -180 to 180, are returned
        in 1 degree increments. The endpoint is excluded.
    Returns:
      list of coordinates for the circle/ellipse
    Notes:
     You can also use np.linspace if you want to specify point numbers.
     np.linspace(start, stop, num=50, endpoint=True, retstep=False)
     np.linspace(-180, 180, num=720, endpoint=True, retstep=False)
    import numpy as np
    if clockwise:
        angles = np.deg2rad(np.arange(180.0, -180.0-theta, step=-theta))
    else:
        angles = np.deg2rad(np.arange(-180.0, 180.0+theta, step=theta))
    x_s = radius*np.cos(angles)            # X values
    y_s = radius*np.sin(angles) * scale    # Y values
    pnts = np.c_[x_s, y_s]
    pnts = pnts + [xc, yc]
    return pnts
Then feed the points into
array = arcpy.Array([arcpy.Point(*coords) for coords in pnts])
rec = arcpy.Polygon(array)  # or Polyline
... sort of retired...
