ArcPro is not recognizing an image folder
2753
11-19-2020 08:27 AM
BrentBrumfield
When creating an imagery workspace in Pro (2.6.2), using the New Workspace tool, the tool doesn't seem to recognize the folder that contains the imagery. Step 1: type is set to drone and basemap is set to Topo. Regardless if I check "Import and use existing image collection", the issue still happens.
On step 2  with the import box checked from step one:
When I select browse then navigate to the folder containing all of the images, the tool is wanting me to select an image and a band... as if it doesn't recognize that the folder contains images...?
A similar issues happens while trying to import induvial images, it wants me to select a color band, not the image.
The file type for the image(s) is JPG.
 It will not allow me to import all of the images like i have in the past. the issue is frustrating me.
Any help would be much apricated! Thank you in advance
by Anonymous User
Not applicable
I am also having issues with this.
CA2
ArcGIS Pro, can you help us out with these concepts? I was working on pulling in a jpeg or png (understandably loses data, yes) to georeference and ArcGIS Pro won't recognize that the file is even in the folder to pull it into the map, not using import, add data, etc. ??
Metal
I have a similar problem but cannot see any input from ArcGIS?! very strange!
