ArcPro Graphic Glitch
1173
12-22-2022 06:41 AM
ccaldwell
I am curious what would cause this issue with ArcPro where when zoomed to a certain point (~1:60,000 and in) the basemaps glitch as can be seen in the photo attached. Is this a matter of the computer hardware not being sufficient? Thanks!
Robert_LeClair
Esri Esteemed Contributor
@ccaldwell - I've created a new ArcGIS Pro 3.0.3 project, found the same exact area in the World Topographic basemap, zoomed in and out at 1:60,000 and do not see the same lines from the lakes you do.  A couple things to try:
  1. Run the Can your computer run ArcGIS Pro 3.0? tool to see if your hardware is sufficient.
  2. Update your video card drivers.
  3. Go to your Project->Options->Display and clear your cache.
  4. Rename your ESRI folder in your C:\users\<user_profile>\appdata\local and C:\users\<user_profile>\appdata\roaming to ESRI_OLD.
Does the issue persist?
