ArcPro Download Location for Updates
2218
12
03-21-2022 07:51 AM
MichaelKohler
I have pro running on a vm with limited disk space. When I tried updating this morning, the update didn't finish because of an "out of space" error. I canceled the install and in the process my machine lost over 2.5 GB of space. I was thinking this might be an issue for this machine so I checked storage space before I started.
Where would've ArcPro saved any files that were downloaded?
BillFox
MVP Frequent Contributor
Do you have the patch available in a shared network folder?
MichaelKohler
yes.
BillFox
do you have the minimum 32 GB or more of free space before applying the patch?
MichaelKohler
on the vm (no) or the shared network drive (yes)?
BillFox
do you have the vm privileges to add a some free space?
MichaelKohler
No. I can't get anymore either.
BillFox
Do you have options to free up some disk space other than what you are asking about here?
If disk space is already that tight even Microsoft updates will begin failing too.
And as C: goes to zero for any reason you might not be able to login to the vm at all without adding some free space.
MichaelKohler
yes I am freeing up space and would love to get rid of this 2.5+ GB.
MichaelKohler
I don't know if this is true or if the files are still hiding somewhere but a restart of the vm might have emptied out some stuff.
