Cannot Pan To, Zoom To or Flash selected or unselected records in attribute table
945
10-02-2024 01:29 PM
doronwen
This is embarrassing, but I cannot figure out why when I right click on a selected/unselected/highlighted record and click zoom-to, pan-to or flash the map does not reply? Am I missing a setting somewhere?
I also should mention it happens only when I use the 'select by attribute' option.
Laura
by MVP Regular Contributor
Mine works fine no matter selected by attribute or not. Can you confirm that those points have a geo location?
Laura
doronwen
I think you are right. That is the issue. Thanks for point that out. My bad.
