ArcPro crashing when exporting excel to table
3096
7
08-19-2021 10:46 AM
RandyMcGregor3
I have a python script that works fine, but lately is crashing on the following line:
arcpy.conversion.ExcelToTable(ef,out_tab)
I can run excel to table fine from the map but it crashes in the python script.
Completely shuts down the arcgis pro document.
Is there some known issue with ArcPro and this command in arcpy?
Thank you,
Randy
JoeBorgione
Does it work as a stand alone script run from a python console?
That should just about do it....
RandyMcGregor3
Thank you. Good question. The answer is, 'no' It does not. Instant Arcpro crash. I ran it as a geoprocessing tool and it went fine. I copied the history as a python script and pasted it in and ran from the console.
RandyMcGregor3
I spoke to soon - It does not crash when run from the python window within arcpro. It seems to have once, but is working now.
JoeBorgione
RandyMcGregor3
Ugh. It's working now. This problem comes and goes and it's gone (for now).
WilliamKresan
I've been running into this for near a month now. The Geoproccessing tool crashes, the Notebook crashes, the Python Window crashes.
It will generate the excel file for me, however, I have to Task Manager out of Pro each time.
Any possible update with known bugs with this tool? Currently in 3.0
AimeeJones
There's some new x64 and x86 driver updates and an Access Database 2016 driver database that fixed mine temporarily. It seems to have issues again after only 3 weeks.
