ArcPro 3.3. not opening?
2814
5
10-22-2024 09:53 AM
Labels (2)
h2e_nwilson
ArcPro will not open for me on 2 of my computers. Running version 3.3. I've tried repair reinstall and a hard uninstall and reinstall. Not sure what else to do here. Anyone else having issues just opening the software??
Edit: to add context, i do have .net desktop runtime installed. version 8.0.10
ronaldbruzzese
same issue as of 1:00 pm est.  opened technical support ticket, will report back with findings.
ChrisUnderwood
Hello @h2e_nwilson  could you try starting ArcGIS Pro in diagnostic mode, and compare your working machines to the failing ones ? Perhaps using a command something like this.
C:\Users\myusername>C:\Users\myusername\AppData\Local\Programs\ArcGIS\Pro\bin\ArcGISPro.exe /enablediagnostics
https://pro.arcgis.com/en/pro-app/latest/get-started/arcgis-diagnostic-monitor.htm#ESRI_SECTION1_59C...
ronaldbruzzese22
without any changes, all computers that had issues yesterday are working today.  no idea if it was on our side of the fence or esri's.  good luck.
ShaneONeill_144
Are you receiving any error messages when Pro won't open for you? It might be worth doing a clean uninstall and reinstall of Pro to see if that works.
ShaneONeill_144
Additionally,
Additionally, try uninstalling all versions of .NET that are currently installed on your machine (6.x and 8.x if both are installed) and then redownloaded .NET 8.0.10 from the Microsoft website (below). Following this, try opening Pro to see if that works.
