ArcPro 2.4.2: The “create utility network” tool fails and ends up with “The table was not found” error,
1892
10-26-2019 12:31 PM
JamalNUMAN
Legendary Contributor
I couldn’t figure out why the “create utility network” tool fails and ends up with “The table was not found” error.
Jamal Numan
DanPatterson_Retired
error/warning 001400
001400: Only the data owner may execute .—Help | ArcGIS Desktop
perhaps the table not found issue is related to a non-owner querying the table
JamalNUMAN
I think that the database needs to be accessed by a user (say jamal) other than the sa or dbo. In addition to that, the dataset (at which the UN will be created) needs to be create by that user as well. Not sure why the dbo or sa users are not able to do so.
Jamal Numan
Contact tech support.  It may be a limitation or a requirement.  They are the only ones that can make that determination.
