ArcPro 2.4.2: ArcPro is much slower than ArcMap in publishing (Performance issue),
2353
10-21-2019 12:56 PM
JamalNUMAN
Legendary Contributor
I’m not sure if users observe that ArcPro is much slower than ArcMap in publishing.
Is this already considered to be resolved in the upcoming releases?
Jamal Numan
KoryKramer
Esri Esteemed Contributor
Jamal NUMAN‌ do you have publishing times showing the difference between ArcMap and ArcGIS Pro?
ThomasColson
Kory Kramer‌, see my post in EAP on this topic, and my suspicion of the cause of the performance problem.
KoryKramer
Thanks, Tom.  Great detail provided in that EAC post, and it looks like the Sharing team is investigating.  We would need more details from Jamal NUMAN‌ to begin to understand differences he's seeing between ArcMap and ArcGIS Pro.
Thanks again!
JamalNUMAN
This is an easy assignment for me! Please, have a look on the screenshots below that show the time elapsed in publishing same data with same environment with Pro and ArcMap. Numbers are telling the story!
What do you think?
Jamal Numan
KoryKramer
Thanks, Jamal.  The team is investigating.  We'll circle back if more details are needed.
Thank you
