ArcMap editor tracking fields not supported in ArcGIS Pro
927
09-10-2024 01:10 AM
SOTIRIOSTRIANTOS
We have created in the past numerous feature classes using ArcMap and we have exported them using sde in an SQL Server (version 12). Nowadays when we import from sql server the editor tracking fields Creation_Date and Last_Edit_Date are not recognized in ArcGIS Pro. I think the problem is that they have an asterisk ie *Creation_Date (high precision ms). This happens from version 3.1 onwards.
Any help?
ChrisUnderwood
Hello @SOTIRIOSTRIANTOS , unfortunately, SQL Server version 12 is too old for ArcGIS Pro 3.1 onwards. Could that be part of the problem that you are seeing ?
ArcGIS 11.1 and ArcGIS Pro 3.1 requirements for Microsoft SQL Server—ArcGIS Enterprise | Documentati...
SOTIRIOSTRIANTOS
No its irrelevant i tested with SQL Server version 16 and the problem persists. The date fields are datetime2(7) type. I tried to export a feature class with enabled editor tracking (the field names where given from Arcmap) to SQL Server and then i re imported it but then it didnt recognize the date fields
