ArcGIS Solutions cannot modify domains for Portal Hosted FS
1560
12-12-2019 06:04 AM
PeggyFung
I have installed the ArcGIS Solutions add-in to ArcGIS Pro 2.4.2, so that I can modify the domain of my hosted feature service on ArcGIS Enterprise Portal 10.6.1.
Here are my steps:
  1. In ArcGIS Pro, I add my HFS to a new map from My Content (this confirms I am signed in as the owner)
  2. Launch ArcGIS Solutions
  3. Click 'Sign in to ArcGIS Organization > Finish
  4. Click 'Configure an ArcGIS Solution' > Next Step > Skip (do not need to add any new fields)
  5. In the 'Modify Domains' window, I select the layer from the drop down list > this loads the fields in the 'Field's drop down list. However, I get a red X in the Input Layer or Table saying Error Unable to connect to the Hosted Feature Service (see attached)
I am not sure why I am getting that error - I even tried in step 4 to add a field and it successfully added a field, so it shows that it was able to reach out to the hosted feature service.
I also repeated the same steps for an ArcGIS Online hosted feature service, and I was able to successfully run the tool to modify domains.
Any ideas?
Thank you,
Peggy
AndreaFagan
Peggy, did you ever figure out why this was happening? I'm having similar issues modifying an existing domain for a deployed solution using the deployment tool tools. I'm getting a different error but my hunch is that they're related. I can add new fields, add a new domain with new values, but I can't modify an existing domain in a solution. It tells me (via server logs) that the service.../mapserver can't be found. The tool points to the feature server and I can't change that... I'm just not understanding what's happening. Thanks!
