ArcGIS Pro3.1 transformation issue
626
09-02-2024 04:42 PM
DamienPyne
I am trying to consume a service from our ArcGIS Server 10.31 dataset into Pro with our utility network dataset and cannot get the transformation to work.
The UNM data is in GDA2020 (EPSG7844), and the older data is web mercator (EPSG3857).
This appears to be an incompatibility between AGP 3.1.x to ArcGIS Server 10.31. It is noted that AGS 10.31 is no longer a supported product. It's noted that AGS 10.31 does not support GDA2020 transformation and it has to be done manually through a client application (like AGP 3.1.x).
When adding Web Auxilairy sphere services (EPSG 102100, 3857), the 3.1.x AGP client application does not apply the spatial transformation locally for map objects set in GDA2020. The service fails to display geometry.
Is this a known issue?  Does anyone have an approach to overcome this?
