ArcGIS Pro
2913
7
04-30-2020 05:43 AM
RudyCharlot1
Good morning everyone,
Upon opening an existing ArcGIS Pro project this morning and see the below kind of thing on my map project.  Does anyone know how to fix this please?
Sincerely,
Rudy
George_Thompson
Esri Notable Contributor
Do you have a mosaic dataset in the TOC?
--- George T.
RudyCharlot1
Yes I do, it is the imagery added from Basemap ribbon.
Rudy
George_Thompson
So if you remove the base map or MD does the pattern go away?
--- George T.
RudyCharlot1
Yes it does and added a new one from Basemap then it didn't happen again. So, what caused to happen in the first place? do happen to know?
Rudy
George_Thompson
Not off the top of my head. If it happens again, I would contact Esri technical support on this for further investigation.
--- George T.
RudyCharlot1
Okay will do.  Thank you very much for your help!
Best regards,
Rudy Charlot
KoryKramer
Esri Community Moderator
Problem: Mosaic datasets display a checkerboard pattern when viewing from a different machine
and there is another relevant thread over here https://community.esri.com/thread/171719
These should provide more "background" (sorry for the pun).
