ArcGIS Pro will not start anymore
1444
09-13-2024 03:04 PM
BillSmith
Hello,
I maintain an application that uses the ArcGIS Pro SDK, so I am often installing/removing different versions to compile against.  The lasts time I tried to install 3.0, it wouldn't start.  So I checked ArcGIS Pro and it wouldn't start.  I've tried un-installing, repairing, cleaning the registry, wiping all files on the hard drive related to PRO.
Nothing works.  I just keep getting this in the Event Log.
Faulting application name: ArcGISPro.exe, version: 3.0.6.36057, time stamp: 0x6216d2c0
Faulting module name: KERNELBASE.dll, version: 10.0.19041.4717, time stamp: 0x16b0a901
Exception code: 0xe0434352
Fault offset: 0x000000000003b699
Faulting process id: 0x87c0
Faulting application start time: 0x01dafa07bc789553
Faulting application path: C:\Program Files\ArcGIS\Pro\bin\ArcGISPro.exe
Faulting module path: C:\WINDOWS\System32\KERNELBASE.dll
Report Id: c57fb378-b77d-4d0d-beb7-09cd267877ed
I was about to call support, but I thought I would post here first.
-Bill
Tags (1)
DanielFox1
Hi @BillSmith
Sorry to hear that you are having this issue. Based on the error message you quoted above here is the respective Microsoft page around the KernelBase.dll
https://learn.microsoft.com/en-us/answers/questions/1180906/geeting-error-while-running-custom-servi...
If you have not attempted a clean uninstall (see documentation below) I would then consider the link above if possible.
https://support.esri.com/en-us/knowledge-base/how-to-perform-a-clean-uninstall-and-reinstall-of-arcg...
