ARCGIS PRO - VERTICE AND NODE EDITS WON'T TURN OFF
1077
07-25-2025 08:36 AM
nimitz
I'm a seasoned Arc Desktop user who is still getting up to speed on Pro. I tried to edit some geodatabase files, (some lines) and I was trying to grip some nodes and vertices. Only now, I can't turn off the nodes and vertices symbols. It's like I was editing and moving some vertices and stopped editing - but I can't turn it off. It makes the screen SUPER crowded.
TIA
AyanPalit
@nimitz If you are using the Vertices and Nodes , its a toggle button to enable/disable.
Ayan Palit | Principal Consultant Esri
CodyPatterson
MVP Regular Contributor
Hey @nimitz
Would it be possible that you're still in an edit mode? I would try clicking this here:
It may be the chance that it continues in that mode, you may need to click the select button above, and then onto an empty space on the map, otherwise, I would restart the Pro project!
Cody
AyanPalit
nimitz
I can't seem to find the toggle.
CodyPatterson
Hey @nimitz
It should be right here at the bottom of your ArcGIS Pro window:
It looks exactly like what Ayan was saying!
Cody
nimitz
My bad. I thought it was at the top. Many thanks for the help!
