ArcGIS Pro Trial : RuntimeError: Not signed on to Portal
1076
08-16-2017 05:00 AM
RichardStyer
I am trying to use the ArcGIS Pro trial download.  I wanted to use the Python command window to see how Python script run.  I downloaded and installed ArcGIS Pro to run as a trial but I need to use it on a network that is offline and cannot connect to the internet or the portal.  As soon as I try to run a python script with
python raster2DTED.py
I get a couple of message about the arcPy and then a RunTimeError: Not signed on to the portal.  I tried opening ArcGIS Pro and it takes me to the licensing.
AdrianWelsh
MVP Honored Contributor
Richard,
Were you able to find a solution to this issue? Did it eventually start working for you?
