Arcgis Pro Tasks Operation
3208
09-29-2016 02:40 AM
NicolasFaget1
Greetings all,
I need help to work whith Arcgis Pro Tasks.
It is very simple. I want to create a task wich select a feature and zoom over.
The task does :
  1. input, the user must enter text (copy the text in a variable) and click run
  2. the task does a sql request like "select * from stops where name like '%variable%'"
  3. zoom on the feature selected
I don't know how to do. I can not find an example.
Thanks in advance.
Nicolas
AmirBar-Maor
Hello Nicolas,
This is how to do it:
Step 1- Select by Attributes: set your layer and SQL query to select the features.
Step 2 - automatic step, set the corresponding layer as selected (must be the only selected layer) and call the command 'Zoom To Selection'
You cannot use a Task variable (e.g. attribute value from user or feature) and insert it into a SQL query.
You can log this as an idea.
Amir
HNoakes
I'm am trying to use a Task variable and pass it into a Python script as a parameter (which I have created as a Geoprocessing Tool for the next step).
I have configured the step to Copy attribute to variable prior to command execution but I can't figure out how to pass the variable into the command. I have tried #variable#, %variable%, !#variable#! etc.
Is this possible?
Heather
AmirBar-Maor
Hi Heather
At this moment task variables can only be used as part of a field calculation.
We are considering to expand this in the future
Amir
LanceKirby2
Hey did you ever get this to work?
