ArcGIS Pro Task - calculate field
3070
6
03-19-2018 05:28 AM
TorbjørnDalløkken2
I'm working with a quite small and hopefully easy task in ArcGIS Pro, but I'm having some trouble getting the correct result.
We have two featureclasses, one with polylines and one with points. The points are all snapped to the lines. One of the fields in the polyline-class contains a value for rotation, and we want to transfer the value to the corresponding points.
I've created a task with the following steps:
1. create point (line snappable)
2a. select layer by location (line based on point)
2b. (when exiting the step) copy attribute from line
3a. Save edits
3b. (when starting the step) calculate field in pointclass
The steps seems to run fine, but the step 3b does not work. The field is not calculated with the copied values.
The fieldtype of the rotation is double. If I try to calculate the copied attribute to a field with the fieldtype text, it works ok.
Regards, Torbjørn
DanPatterson_Retired
You would have to show your data and the calculate field expression.  If it works with text but not a number then something is causing this
ProvidenceAdu
Hi Dan,
Please I am trying to use ArcGIS Pro tasks for some of our repetitive workflows.
1. How do I automatically configure the Merge tool to Merge Existing features instead of New features, when I automate it in Task? It automatically runs new features and create unwanted duplicates (see attached Image)
2. How do I set a fixed scale for features (eg. 1:8,00), without manually typing the scale in? which command in tasks provides that functionality?
Thank you,
AndrewHargreaves2
Hi Dan Patterson
I'm having a very similar issue when attempting to run a field calculation on features appended using a Pro Task. The append works fine, but I ask the Task to also calculate three values on  those newly appended "Features or records created in this step" . These field calc's fail to occur. Screenshots of my setup are below:
Andrew, I don't use tasks, but I can only guess one of several possibilities.
Are the fields you are calculating into of the right type (is you show Status = 1... so Status is a numeric field?)
The fields you are calculating into do they exist in the table that you are appending to? or in the table you are appending?  The former would be correct
AndrewHargreaves2
Dan Patterson‌ - yes, status exists and is a numeric field
Ok... I misread append as join, so skip the second comment.
It is the order of when things get done.  My guess by reading your inputs, is that I am not sure what to expect
since it looks like it is supposed to calculate those fields after the records have been added, but I don't know if you need to 'do' something prior to that step
